Post your Workspace Setup
I thought it might be fun to see how you guys are using the new configurable workspace feature.
To kick things off, I’ll go first with my favorite setup!
Mine:
Nice, and that was quick!
If I’d only had the space :wink: Working on a 16 inch MBP.
I have a 16-inch and manage to get an extra column with the node browser into the setup :blush:
True. I managed to put the resources right next to the settings tab. Still… one more would be great.
Don’t forget you can also split the panels vertically…
Riiight. That helps.
Currently:
For coding on a MBP 16" the default works best for me (for now)
This is my favorite setup.
The only thing I would like to be able to do is to somehow only have the Page Settings visible underneath the page panel. The way it is now it is always visible in the left sidebar regardless of which panel is being displayed above it.
Normally, I would have the components displayed in the left sidebar, which does not need the page settings displayed below it.
This is my coding setup.
Just finished finalizing three setups: Code, Compact, and Favorite!
Changed my first setup : Discovered the possibility to stack different sections vertically in a column: very useful application for working on a MacBook, for example. Optimal use of available space.
