Poster Stack and Easy CMS work together?
Hi - I’m looking to create a case study type of main page that then links through to individual case study pages much like a portfolio setup. I’m interested in the Poster Stack but does anyone know if this can be used with Easy CMS?
It should work as there isn’t anything complicated from a CMS point of view in the Poster content which is just normal content.
Hi Gary - great… I’ll give it a go. Any tips on doing it as I’m a bit of a newbie to RapidWeaver? Many thanks
I would say there is a fair bit to learn if you are new to RapidWeaver. Setting up a CMS system in Poster is fairly advanced but certainly possible if you take it all stage by stage. I would tackle EasyCMS first and setup some page content that you can edit remotely.
Hi - sounds like a plan. I’ve come over from Freeway Pro and RW is quite a different setup but seems to have endless possibilities. I’ll give EastCMS a go and then see if I can integrate it as you suggest. Thanks for you help
