I have simply referenced in the various stack to use âWarehoused Imagesâ rather than local and then set the link to my âhttp:wwwâŚâ domain where a folder named âassetsâ resides.
I then FTP those images to the 'assets" folder
The images render as expected with no issues.
Indeed when I publish locally and check the various page folders the warehoused images suddenly appear !! - hence being puzzled
After publishing locally and then inspecting the published folder with Finder it is then that I have discovered the images and interestingly those images do not have the same filenames as I named them prior to FTP.
Given your comments I have doubled checked on the published server site and indeed I can confirm that those images are also resident in the file structure there.
It could be that if you donât delete the local image from stacks, and then choose to use a warehoused image, that the local version will still exist in the file. You can see these images in the project file after a reload so I wouldnât be surprised if they are republished even though you are no longer using them.
I did once use local images but then "crossed out "the image use and configured the warehouse image.
I assumed that by simply selecting warehouse images all would be good to go.
What I did also do locally was to delete the published folder entirely and republished afterwards using the warehoused image set-up - but still the images re-appeared locally.
Being very new to RW + Foundation Iâm not too clear on how I would go about deleting the local files - if that is what I need to do - can you advise what I should be doing ?
In a way it can be handy to have the local image still in the project file so that you can go back and use a different image during the development phase. It is a bit clunky though.
RWâs whole handling of images is just clunky IMHO.
So after following the advise given I went through all of my pages and stacks disabling the warehousing in order to expose any locally âhiddenâ images (a few were indeed found) which enabled me to click the âxâ delete button and then restore the warehoused versions (it was good to see that the url path to the warehoused versions wasnât lost which saved me having to utilise text-expander to help with that possible task !!)
I then deleted the entire site folder both locally and on my server and republished to both.
As predicted all local image files were no longer present and the site references the warehoused images (and videos) without issue.
When I looked at the site folder size previously - with some of the local images intact - it stood around 15mb.
This size has now reduced significantly down to 6mb which is a welcome saving.
As you are aware the site is still in formulation but I believe I am now working much faster and more efficiently thanks to your help - Robert at Joe Workmans and Andy Tavernor at Big White Duck.
Thanks to you all for your help in making my transition from Freeway much easier than it would have been.
