It looks like I need to warehouse my images, rather than “upload” them through the stack’ settings.
I want your suggestion on where to create a Warehouse/Asset folder within my FTP folders?
I am using a separate RW-project for building my newsletters’ mails, so does it mean I need to create the Asset folder for my warehouse images outside the public_html folder where my all the files of my site are located?
I don’t know how Joes Email Stack works in regards to images.
You could use a FTP app to upload images to a server folder, problematic there an easy way to get the live link of the image
You could upload images to Mad Mini, there the challenge to get it displayed in RW correctly
A nice way is to use Repository Stack and its image upload / copy URL to clipboard functionality. With that, you are easily able to warehouse your images and include them in RW pages or emails.
There is the possibility to use a Warehouse Image by simply changing the settings.
I thing I would opt for this option by using Filezilla.
Do you suggest to create an Asset folder for my Warehoused Images inside the public_html or on a separate folder?
Thanks for suggesting Repository Stack, but I think I am all set to make it work with the resources I already got.
Unfortunately, inside RW this is not working. I get a question mark icon, instead of the image.
Also, if I hover on top of the Warehouse icon inside the stack setting, this message shows up: “Local image or warehouse image must be published in order to work inside your email”.
The image is showing on Preview inside RW now!.
One question, Is it normal that in Edit mode a Warehoused image is displayed with the question mark icon?
I am not sure on that one, I believe it will show what it can in edit mode, and since it could not find the image, it showed the default web standard for missing image, but I could be wrong.
I inserted the URL again, after deleting and re-inserting the stack and is now working super duper fine !!!. It is showing well both in the Edit and in Preview Mode.
Awesome!
I am going to try if it is now going to display on MailChimp.
@Adri12
I have found that if I change a warehoused image or correct the url having entered it erroneously and been given the question mark icon, then the change is often reflected immediately in Preview but not in Edit.
You asked if this is normal. It is, though ideally it would update in edit too so I think it’s a bug.
The only sure-fire way to get a changed warehoused image to update in edit mode is to close the project and re-open it.
