Hey @rob, I would like to customize the icon used when a products is marked as “unavailable”
Is this currently an option within the RCP settings?
Also, is it possible to add a custom url to a product’s button when it is marked as “unavailable”. I would like to have the button direct to an external page.
You can’t customize the icon from the plugin interface.
You can edit a PHP file where icon is hard-coded.
File to edit is versions.php located in /rw_common/plugins/rapidcartpro/templates/product/ folder.
Change uk-icon-ban code at line 52 with your preferred icon.
Complete icons list is available at Icon - UIkit.
