I was as thinking of upgrading my MacBook Air to Sequoia. Will Rapidweaver 8 work fine with Sequoia?
I’m running RW 8 on an M2 MBA and so far the only issue I’ve had is that DateLoom is too outdated to use. I had to delete it and, so far, everything else that I’ve tried has worked well.
You can use RW8 on Sequoia, but it is unsupported.
RapidWeaver Classic contains many improvements, and fixes for Sequoia.
Maybe see how you get on with RW8, and if you hit any issues, you can always upgrade.
Thanks for the reply !
