RapidWeaver 8 Upgrade Question
Hello, Upgrade to RW 8 Question:
I purchased RW-7 from the MacApp store. I run it on 3-Macs. I want to upgrade to RW-8. I know I can wait for the MacApp store version or buy direct…
If I buy a upgrade direct from RealMac ( upgrading from the MacApp Store version) will I be able to run it on 3-Macs or do I need to buy a full license (5-macs) from RealMac?
This should answer your question:
Thank you Robert. You are a scholar and a gentleman …
Glad to be of some help!
