Hi, I have Rapid weaver 4.4.2 - Can I upgrade to 6?
Maybe. But why not upgrade to the latest version 8?!? Version 6 is completely outdated for some time now…
What Version of MacOS are you running?
As @RapidBase pointed out the latest version is RW8. The upgrade from RW 4.x is pretty much rebuild the site(s). If you are running MacOS 10.12 or higher then RW8 is the way to go.
Hi My operating system is El Capitan 10.11.6 and need RW for this -
RW 7.5.x is the newest for that macOS.
Not sure about upgrading licenses.
You can get older versions here:
Thank you so much. Will find out if I can upgrade to 7. Angela.
Thank you so much.
