In RW6 Is there an equivalent of the old ‘Replace’ a page type in RW5?
If not, what is the preferred way to change a Page Type, please?
TIA!
TIA!
Delete page. Add page.
Thanks; Changing an existing page’s type would be useful, wouldn’t it!
Yeah, I used replace a lot in RW5 but it’s not that much more of a hassle because you still needed to change the folder name anyway…
Only one more step to change the page in RW6.
Yes - and there are so many advantages to RW6, which I like a lot and find works so well
For our notes: what data / information are you looking to keep on the new page? Filename / metatags etc?
—N
Nik,
As much as possible, I think
But I appreciate there are other higher priorities for you; RW6 is such a delight. Thanks!
If at some stage what was there in RW5 could also be here in 6, that’d be terrific. Good luck!
