Responsive page two columns /Paysnap
Hi
Running RW 8, using Solitude theme, I’ve created a two colour stack standard page which I assume works within the responsive theme ? www.croydecoffee.com/Coffee_Shop/
The page loads and displays ok on a mobile if you hold the device in landscape, but only shows one side of the shop in Portrait mode.
Any ideas please ?
Many thanks.
Not sure where some of the CSS is coming from. You have some fixed width stuff at 800px?
2021-04-03_12-53-57
I don’t know if that is something you put in or where it is coming from?
I don’t have PaySnap or Solitude, so I can’t try to reproduce what you have.
I never use the default stacks columns as their breakpoint is way to small to stack columns and isn’t user set-able.
Thank you Doug, Ill look into your point.
Many thanks
David
