I have been given a piece of script () to insert into a Rapidweaver 8 site. This is for a retargeting pixel. How do I do this?
What kind of script? JavaScript, PHP, svg, etc etc.
Yes. Javascript. Can I simply go to the Code area then paste into the Head area? It is intended to be on all pages.
Without knowing the code, it’s hard to say for sure.
If the script has <script>
tags around it, then you could try putting it in the head section.
You can also try it without the script tags in the JavaScript area.
Thanks so much. I’ll give it a try in the head section as it does have tags. If that doesn’t work I’ll try the JavaScript area
