There are setting in my Fluid Image stack that can cause the image to grow to the container width. You can turn that off. You can also define a max width.
Hey Joe- Good to hear from you- I’ve tried all the settings I could find in Fluid Image. What setting are you referring to that I’m probably missing. I’ve defined the max width over and over will no luck.
Hey- Just found it… I was defining the image size within image settings. But I just discovered to get to to the setting you’re talking about within the stack, you have to Select the correct setting in the pulldown: Max Scale: Define Max Width.
But, the default Max Scale is: Image Width.
This, as you’re probably guessing, begs the question: If I tell the stack to go with the image width, why is it scaling outside the image width?
