I’m sure that they will work with RW7. I have worked now for many weeks with RW7(beta) and didn’t experience any issues with any theme.
Hm, maybe “Kinfolk” from Michael David Design? http://michaeldaviddesign.com/themes/kinfolk/slideshow/
But this stack should theoretically work with any theme. Either by placing it at the top of all Stacks content or by using Extra Content areas. But that differs from theme to theme…
I would say “no”. At least it won’t be easy, since this would have to be hard-coded into the theme by changing the html-template inside the theme. If you absolutely want the menu bar to be positioned this way I would suggest looking for another theme or simply use a free-layout theme like Foundation, Freestack, Bootsnap, UIkit etc…
Thanks Matthias for your answers, yes I saw “Kinfolk” and I like it, but did not want to purchase it, maybe I should
Also thanks for no. 3 tip!
regards
Monica
