Is there a way that you can change how you search for things such as themes. IE categorize it better. If I am looking for a horizontal navigation bar that is compatible with RW7 I want to be able to find it and as it sits now, I can’t find a dang thing in your store with the set up that you have. I have to go to the forums and ask questions and hope some one steers me in the direction I need to go.
I am using uiKit with both horizontal and vertical navigation on my current sites. you could also use foundation to create what ever you want
@scottsteven
Can you send me a few links so I can see your site?
