can anyone help me as to why my themes are loading up and what I can do to solve this
many thanks
josh
Is your version of RWMultiTool compatible with RW7? I think it should be at least 2.2.2.
its a new rapidwqeaver and I bought rwmultitool literally 2 days ago
I don’t own Multitool but this thread suggests it only works with certain themes:
Also there is this post from their website:
• Why when I launch RWmultitool I don’t see any theme in the theme list of RWmultitool?
Probably there are no editable themes in RapidWeaver folder. Please, make a copy of a Default RW Theme or install a Third Parts Theme.RWmultitool opens only the Themes placed in the folder named:
/library/application support/rapidweaver in RapidWeaver 5 (RWmultitool for RW5)
/Users/youraccount/Library/Containers/com.realmacsoftware.rapidweaver6/Data/Library/Application Support/RapidWeaver/Themes/ in RapidWeaver 6 (RWmultitool for RW6)If you want to edit a RW Theme you must first make a copy of it inside RW (Theme Drawer) or place a downloaded third parts theme in that folder.
Note: If you cant see any theme installed in the theme menu, enable “view all themes” check.
The file location is for RW6 but you could try the same process for RW 7
Hi cheers for the help
I am still struggling as im quite new to this but haven’t got any idea on what to do to add the themes into RWMULTIWEAVER
many thanks
josh
http://bltthemes.com/preview/rapidweaver/vertigo/
if my RWMULTITHEME DOESNT WORK does anyone know a CSS code to change the banner on this
Did you try this from your other post:
