Anyone know if there’s a way to add a light shadow box behind the title and slogan in the Mountain theme? Thank you in advance.
You could try some custom CSS code like this to apply a background shade behind the title / slogan in the Mountains theme:
.hero-content .container {
padding: 4vw;
background-color: rgba(0, 0, 0, 0.7);
line-height: 1.2;
Which would result in:
If you wanted a box-shadow, effect around the box, then modify the code as follows:
padding: 4vw;
line-height: 1.2;
-webkit-box-shadow: 10px 10px 5px 0px rgba(0,0,0,0.75);
-moz-box-shadow: 10px 10px 5px 0px rgba(0,0,0,0.75);
To generate the CSS code for your box shadow, you can use a free tool like this: Box Shadow CSS Generator | CSSmatic
Thank you for this, Will. It worked perfectly. I changed the code a bit to lighten the box and it’s terrific. Many thank you’s.
