I need to set a link within an iframe either to _parent or _top… so that the link triggers the parent window.
How do I do this simply from RW’s link window?
(Can’t seem to set “target” as an attribute for some reason)
Me too. I just asked this yesterday and it’s slipping down the list.
Woah. Why must there be a trick? I’m surprised!
Update–
@el_mourabbi the trick you described hasn’t worked for me so far
I found a solution that works!
I put this small snippet in the page inspector, in the HEAD area of the iFrame
https://www.dropbox.com/s/dcoeoxy0cmuktun/Capture.JPG?dl=0[EDIT - I thought this solution didn’t work on iOS, but that was operator error on my part :)]
DONE!
A
