Anyone know if there is a macro to use the site language? Can’t see it listed anywhere and have tried a few guesses (%lang% etc) to no avail.
@ben?
@ben?
This is not available via a macro and is done programatically at the top of the document, e.g.
<html lang="en"><head>
Can you let us know why you might need this and we could see about adding it to RapidWeaver 9
Cheers
D
Ah ok. Thanks @dan. First time playing with a theme. I had put <html lang="en"><head>
in as a placeholder so just leaving it out completely is all I needed to do. Cheers.
Just remove the lang
attribute and RapidWeaver will insert it into your existing html
tag
