Small issue on Image and Text Component
When rounding the Image and Text component, there is a light remnant in the corners.
I couldn’t recreate this issue, do you have the “Image & Text” component inside another Component? I’m thinking the wrapper element is giving the white colour, not the Image & Text component…
Can we see a screenshot of the node tree, or maybe post the project so we can take a look?
Based on your reply, I see the issue Dan. I used a container component and put the Image and Text component in it. So now I removed that and adjusted the wrapper settings on the Image and Text component. I was able to remove the issue.
You could have also set the container components BG opacity to 0% like this…
ahha! Ok thank you for the solution Dan!
