Soccer Tables in Elements
Hi Dan,
I have been considering buying the Beta now as I now have an official invite, I spoke to you a long time back with reference to tables, I build and maintain a soccer website for a local club here in UK and was just wondering if this is now a possibility to do within Elements? I want to purchase the Beta but do not want to spend money if this is something that isn’t possible to do, I currently use a different software to build it at the moment but that software has now stopped being supported, I currently have Rapidweaver Classic but I have been following Elements ever since it started and like the look and ease of use it brings but just want to make sure if the above is a possibility with Elements.
Dan sent me some code to create a table for me
I can modify to what I want and with a little bit of copy and paste in the code I got to what I want,
Take a look at the work Bartje has done with Google Sheets. It started in this thread. A thread regarding the component is here.
I have little doubt want you want can be done in Elements.
you can download my Custom Component for Google Sheets via this link.
Thank you to everyone that has replied to my post, I will download from Bartje’s link and see how I get on and thank you all again for your feedback.
Hi Bartje, the link doesn’t work
Strange because the link is generated by Elements.
Hope this one works.
