Social Card not showing in Twitter
My social card I have for my homepage does not appear to be working in Twitter. Is it the path to the image in the RapidWeaver code?
https://abbclife.org/
I would say that is likely the problem. I don’t know of a debugger for Twitter but I ran your site through the Facebook “Sharing Debugger”, rescrapped the site and got the following error:
tag: @dan @simon
Is there a fix coming for this?
Anyone know if this fix will be on the next release?
Yes, they are already working on a fix…
Should be later soon
This fix should be in the next build, early next week. Sorry for the delay.
@teefers, can you send over your project showing this issue to dan@realmacsoftware.com - Thanks!
Dan
I will as soon as I get back in town. Look at the source code on my home page and you will see partial URL to the image location on the Twitter card. https://abbclife.org/
I just sent you an email with sample Project, URL, and Facebook debugger results.
Perfect, expect this to be fixed in the next build!
Cheers
Dan
