SSL Turned on, but "not secure" when browsing
Hi, all, something broke my https connection - unfortunately, I don’t know what did it.
When I visit https://www.miraverde.de I get a “not secure” (or similar) notification in Safari (in Firefox, it’s just a crossed-out lock symbol).
I’ve looked everywhere - I have not http:// references. Period.
However, if I check the page with Firefox developer view, it shows me that there are plenty of http://loads:
Oddly, the Brave browser tells me the site is secure and the certificate valid… I have cleared the cache on both Firefox + Safari… still getting a “not secure” warning.
I’m completely lost here, does anyone have any ideas?
Thank you!
I just checked your site using Safari and it shows a valid certificate. The lock symbol displays correctly.
Looks secure as long as you get there via an HTTPS call.
https://www.miraverde.de/
However, you can still get there with a straight HTTP URL
http://www.miraverde.de/
You should redirect all http calls to https using an htaccess fill.
Run the site through https://www.whynopadlock.com/
It will give you the code for your .htaccess file to force https and that should fix the issue.
Fantastic, thank you so much, Doug!
For some reason, the .htaccess file disappeared and the edit window in RapidWeaver was empty. I was able to roll back to the previous version within RapidWeaver, so I’m assuming something happened to it during an update. Very odd, but you saved the day!
BR Nick
Thank you for checking - very odd indeed, that some browsers will show SSL working and some not.
The issue was caused by a missing .htaccess file.
Hey Rob, thank you for the URL, that site is new to me.
It generates a very specific .htaccess file. My “old” one was more generic, but seemed to do the trick (when available, LOL):
RewriteEngine On
RewriteCond %{HTTPS} !=on
RewriteRule ^(.*)$ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
It’s a great site. I used to use it all the time.
