Store custom components
Is there a way to store of save custom components so they can be used in multiple projects?
Not currently, but it is high on the list.
I know it’s not ideal, but for now you should be able to copy and paste them between projects.
You can copy custom components from one project to another. I have project A and B. B contains a custom component that I want to use in A. Then I select the custom component on page B (note: not in the All Components area but on the website) and drag it into a container of project A. The custom component then appears in the All components area in the Custom Section. Hope that helps.
