narrowed down my issues with no html components disappearing
if I copy a html component straight from one project page to another, it works until I close all down and then reopen the new file in a different directory
how to you copy the html custom component from one project to another but not page to page but in the components section on the left
This is a known issue, copying Custom Components/Globals will not work between projects — they’ll break when you re-open the project, as it’s still referencing the other project.
This will be fixed in an upcoming beta. Stay tuned!
@dan I know you guys have a lot going on, but it has been almost 2 months on this issue and I really have a lot of components/ideas started and need to move components to separate projects, so I can have a clean ‘playground’ for each idea. Pretty please.
ok in edit mode gone in preview,was ok after beta 13 then beta 14 screws it up…im not copying tho just editing the site ive been building…if I create new page with a new html same thing
Sorry, this bug has slipped into the build because of the work we were doing under the hood. The workaround for now is to launch Elements first, then load the document (i.e don’t double click the project from the Finder to launch Elements).
maybe im doing something wrong but that still doesn’t seem to work but as long as I dont have to re enter all the data ive put in I will wait till its fixed
