Stuck creating link to page
Hi All,
(Using Lander theme Pro)
I’ve managed to put a link to ‘terms & conditions’ in the sidebar (extracontent bar at the bottom of the page),
But when i’m testing it it says:
"Not Found
The requested URL /terms-conditions/ was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
Obviously it’s the url it doesn’t like, but I’m stuck as to why? I created the ‘terms-conditions’ page, but it’s not working?
Please help if you can :slightly_smiling_face:
The code:
When you paste the code into your forum post, select it and mark it as code.
On the top </> above where you typed.
Does the new page exist on your site(you published the new page)?
I tried the URL that you had up before and got the 404.
http://apexkravmaga.co.uk/terms-conditions/
Make sure the folder name in the page matches exactly.
I looked at your home page and didn’t see the link you’re talking about, did you not publish yet?
No not published it yet, as was ‘testing’ it using the RW option ‘preview with’ - then the 404 appeared.
Hi Teefers,
Thanks a lot for your advice, I’ve got it working now. Really appreciate your time :slight_smile:
