I have a nice rw site published to mysite com and now I have added a subdomain via cpanel on my server: mysubdomain mysite com and i want to publish a rw project to it. It seems the only valid way to connect an ftp is via the main domain: ftp mysite com - and that works great for my main site. Via cpanel, I can see the new subdomain at the same level as mysite com, AND a public_html where the rw ‘publish’ seems to be putting the files.
How do I get a new rw project to connect and upload to the subdomain?
I have read the posting on the topic but none seem to help me solve my problem.
kr,
-sean
Hi Doug - thanks! I’m working on a namecheap sever; https://server60.web-hosting.com/ which does create a directory the same name as the subdomain - and then mine also has a strange duplicate where it looks like the log on is pasted in front of the subdomain and thats where the cgi-bin is located. So, the rw setting (Browse button) takes me into an empty folder with a “/” >. I pick that and get a “/” in the Path text edit. Test is successful. The files (Ive managed to get it to publish 1 time) go into that subdomain named folder with a floder with my logon info in it. They need to go into the doubled up named one with the cgi-script. I moved all the files into that doubled up name folder and both the subdomain and the redirect to it work as expected. Now I have 2 problems:
1.) I can not get it to consistantly publish to the designated folder (fails after loading most says “ftp problem”) but just worked as I was looking for the error!
2.) I cant seem to designate the folder I would like it to go to
I am wondering if I should just publish locally and then ftp up with an ftp client? I know its maybe a bit unusual?
kr, and thank you!
-sean
