This example screenshot is the component editing function. Can you add an ability to collapse all of the drop downs. It is much easier to find the right control if I can collapse them.
Funnily enough we already have a ticket for this, and I’d like to get it added sooner rather than later!
Adding to this collapse subject: I think a control setting for devs to collapse a particular group by default will help tidy & visually simplify things for users when they first start using a custom element.
That’s a great suggestion ![]()
would make it easier, you have to collapse every single one in each of the 4 quadrants, also when in the editor mode it would be good to have some kind of marker for each dropdown /colour etc, unless there already is, its is tricky working in the editor as is, the scroll bar for copy paste etc is very thin, still would like a pop out editor
is there a search function in the editor
