You have all given me excellent recommendations for themes. Thank you! Now I have another request:
I have been searching high and low for a theme that looks like the attached picture. I have looked at every sample site I could find and over 100 themes. Perhaps someone could give me some recommendations:
Logo and Horizontal navigation in a top band. I could also live with a theme that put the logo and navigation on the top of the header image.
Capacity to put my own image in the header
Ideally, a clickable text in the header
I am currently using RW 6 - mostly because if I upgrade my OS to 10.11, I lose the use of other applications I need. Does anyone have any recommendations? Thank you so much!!
Thumbs up on blank theme idea. I started with Themeflood’s blank theme (there are others too) and added a navigation stack. Themeflood’s blank theme has support for Font Awesome, ExtraContent and more.
Hi - I did look at foundation and it seemed to have a daunting learning curve? At least for the luddites among us. Thanks for the recommendation, I will take another look.
