Hey, I’m currently working with themeflood.com’s two themes: Summit and Volcano.
I was looking for a way to quickly and efficiently visualize in the RW Resources window all the fonts delivered with both themes, as well as the many Background Textures.
For textures, just duplicate the folder located here:
Summit.rwtheme → Show package contents → Contents → images → textures
and place it in the folder containing all the imports used in your project.
(same thing with Volcano.rwtheme, are the same files) -
Here is a download link for this set of images (zip - 3.1 MB):
https://transfernow.net/791ib866u319 -
Finally, then just drag-and-drop these two folders on the Resources window… And here is what the Resources window displays:
NB: if you want the files in the Resources of the window of the same name, the files are arranged in alphabetical order (more logical and more convenient), you need in the Finder you list them in alphabetical order reversed (Z first), select them all and drag and drop them in the Resources window folder…
