I use Foundation 1. The Top Bar Menu doesn’t work on my iPad mini (1st generation, 1024 by 768 pixels). Furthermore, it doesn’t show the menu items in landscape mode at all! In portrait mode, the sandwich symbol is visible, but not clickable. Please see: www.lengyel.de
It works on my MacBook Pro, iPad Pro and iMac Pro and in all RapidWeaver simulations of resolutions, but not on the actual iPad mini.
Hello Doug, yes, it really is a 1st generation (No. A1455) and it runs iOS 9.3.6. Probably, you are right. I didn’t expect problems like this kind of lacking downward compatibility.
According to Wikipedia, iOS 9.3.6 was using Safari 9:
If you use a website like https://caniuse.com/ then you’ll see support for things we take for granted in modern web design (like CSS flexbox, grid, calc, variables and transforms) quickly go into ‘unsupported’ territory, with these older versions of Safari. So I suspect that is the reason things don’t look right for you.
I own an original 1st generation iPad. The very first iPad model ever released way-back in 2010. The ones without cameras on them! It still works as good as the day it came out the box. Except it is near impossible to browse any website on it. Even Apple.com and Google.com won’t load on it.
