Total CMS question
I posted this on the Weaver Space forum.
Using total blog on a home page I have a blog list. I want to have a blog post on the same page.
One of the posts mentioned you could use a blog post set to dynamic but I can’t get that to work.
Is anybody doing this on their home page?
Dynamic just allows you to load a post without the permalink. there are settings that determine which post (latest, first, category etc.)
Maybe explain a little exactly what you are trying to acheve. is the blog list for the same blog as the post?
Are you truing to implement a “You may also like” other articles type of suggestion list?
I’m not sure what the issue is, you can definitely have a blog post and list on the same page.
EDIT: I slapped the blog post at the bottom of this page just to show you: https://sandbox3.cottsinc.com/
