I THOUGHT I had done this!
- Save a partial from one file.
- Opened a different file and found the partial from the first file!
- Dragged it in place.
OR…Did I copy and paste stacks from one file to another and THEN made a partial?
I’m confused…!
I’m confused…!
Drag the partial from your edit area not from the stacks lib.
Finally figured that out, Scott, thanks!
Partials are just stacks. You can copy and paste them between files like any other stacks. Drag and drop works too.
Partials are saved inside the project file, so if you send a RW file to a colleague, they’ll be able to open it and see all the partials.
Isaiah
Thanks, Isaiah… I’m now understanding partials better! Bye R@y
