You should avoid calling a complete reflow if you can and rather just target the element(s) required. If manual resizing with the mouse works though, it is unclear whether a reflow is the correct solution. For example an equalizer or topbar positioning problem as a result of content changes will not get fixed with a window resize and needs the event listener reattaching with the updated element positions via a reflow.
It very much depends on the situation and the element in question. For example most reflows that are needed relate to equalised content in which case just reflow the equalizer, you can find all the components that support reflowing in the Zurb docs.
For example to reflow the equalizer: foundation.jQuery(document).foundation('equalizer','reflow');
similarly for an accordion foundation.jQuery(document).foundation('accordion','reflow');
which is another common case.
If you are going to fire this on a window resize event then you should ensure that this is debounced so it only fires once resizing is complete.
