Uninstalling RapidWeaver 6
I have installed RW7 and all my Stacks / Themes seem good. Can I safely uninstall RW6 now? It is more than two times the size of RW7, so a little worried…
Thx!
I trashed my RW6. Make sure all of your resources are linked in your RW7 projects. If not, then you may still need RW6, although I just manually relinked the resources. I didn’t have a lot of them.
Hi @drsdayton, you can delete RapidWeaver 6 after migrating to RapidWeaver 7. It is not required for RW7 or your projects to function. Just make sure, as @bruce said, all is migrated first!
