Use Desktop Breakpoint - what is ~?
Mac OS 10.13.6
(RW8.2x, Stacks4.0.1, Foundry1.3x)
Hi and good day,
Usually I start designing a page with the desktop page, I then check it on the iPad, then the mobile device.
For custom columns - what is the meaning of ”Use Desktop Breakpoint”, is this setting then used for the tablet and the mobile? or the other way round?
with best regards, Omar KN, Stockholm, Sweden
Hi @OmarKN – Foundry is Mobile first methodology. Your Mobile settings will carry over to the tablet and desktop. If you enable the Tablet breakpoint then the Mobile settings are relegated to just the Mobile breakpoint while Tablet will then be applied to the Tablet and Desktop breakpoint. If you then enable the Desktop breakpoint just the Desktop settings will be applied to the Desktop breakpoint.
