Could somebody please explain to me how in Foundry, using the Foundry Columns stack, you can make sure you get two columns at the desktop screen size, but only one column (or no columns) at the tablet size?
The tablet custom column size for the second column is at least 1 unit, so never zero. As a result , I always still get two columns - in the latter case with the widths of respectively 12 and 1.
As @teefers points out Iâve got a tutorial video that will walk you through using the Custom Columns feature of the stack, among other things. Basically though you want to set the columns at the Tablet breakpoint to both take up the full width, which is 12 units.
In the screenshot above youâll see that our Desktop breakpoint is set so that column 1 and column 2 are set to 6 units (out of a total 12 units). This weâll get two columns side-by-side.
In the Tablet section weâve got column 1 and column 2 set to a full 12 units each. This means only one column will fit on a ârowâ at a time. Hence stacking them one on top on another.
Honestly, it is way easier than I make it sound in my long drawn own text above.
I encourage you to watch the tutorial video. It is far more interesting than me typing it all out here in a forum post.
Thank you so much: The issue is that I did actually watch that 12 minute video before coming to this forum for help AND that I actually have set the custom tablet columns 1one and two at 12 points widthâŚ
Depending on the screen size youâll get the desktop breakpoint. Remember it isnât device centric â it is based off of the width at any given time. Design with width in mind not an arbitrary device name.
Also Apple has now made iPadOS specifically mimic desktop.
I understand itâs the screen size, not the device. It is a really tiny screen though: an iPad mini. Tablets do not come much smaller than this. So you reckon itâs the desktop mimic thing?
Even The original iPad miniâs had a Logical Resolution of 768 x 1024 px. The screen looks small but Logical Resolution is the same as a regular(not pro) iPad, so the breakpoints would work the same.
Unchecking âEqual Height Columnsâ makes the columns behave correctly. @Elixir will have to give us more insight into how it should work with that setting enabled.
I noticed you are using the Container stack to add margins. The only reason to use that stack is if you want to set a max-width for itâs content. For margins, youâre better off using the Margins stack. It also gives you the ability to set margins by breakpoint.
I believe in Foundry v2.x at some point I made this feature work on multiple lines. Essentially it turns off the equal height setting after a certain point. Iâd have to go back and look at my release notes again. I suspect @Jimmy that youâre using an older version of Foundry.
