Using RW and Stacks on more than one Mac
We’re planning to be away for part of the year, so I have just purchased a 12in MacBook to keep in touch with everything. I’d also like to be able to tweak the two RW websites that I oversee. Am I able to install the same RW app and several dozen plugins including Stacks, Foundry etc., onto the MacBook without infringing license agreements or having installation issues? The RW files will reside on DropBox (seems to work okay…)
As long as you start Rapidweaver on only one computer and not both at the same time, it will work.
Thanks!
