I used RW a looong time ago (but I recognize some of the older RW Themes
). I’m currently considering using RW for simpler “one off” sites, these web sites will probably contain a lot of photos and some text. My intention is to create a site, update it for a while, and then just leave it without doing much more to it.
I’ve started to play with Classic, looked a bit at Elements and it looks quite interesting … it’s probably the tool I would like to use in the future. But it looks like it will not be available in the near future … I expect that it will take some time before the beta period is over.
It looks like Elements will not be able to read Classic projects, but what happens if I buy a Classic license now and want to be able to use Elements later? Is that another license? Will the same license work for both apps?
In short, should I start using Classic now or should I forget about RW until later and check to see if Elements is what I want?
