Using Tailwind Components
Can I copy and paste Tailwind UI components into Elements to create custom components?
Essentially yes (although some require JS that you might need to include separately). If you go this route you’ll want to be familiar with Tailwind and HTML so you can customize it yourself.
You can also learn more about building a Tailwind Custom Component in this tutorial I did last week…
Hope that helps!
