Hi..
After some updates the Weather and Weather clean stacks don’t work, Joe Workman.
Can you fix it?
Hi..
Can you fix it?
I believe that Yahoo has killed the API and therefore Weather Clean won’t be able to get the info any more.
Aha… IC
Maybe someone can make a new one?
https://api.met.no
I also have problem with RSS Stream and RSS Typewriter as well.
There is a free (donationware) Weather Embed stack from Stacks4Stacks.
Thanks - I will check this out.
