Hello,
I am very new Rapid Weaver and I purchased the Stripped Theme and in the ExtraContent 4 area the creator’s example shows a slideshow effect. I am using the “free style1” sub theme(http://www.henkvrieselaar.com/Themes/stripped/stacks/freestyle1/). The manual says, “Adding a slide show stack: drag your slide show stack in the ExtraContent stack and select EC4 in the settings of your stack. Add your images as described in the tutorial of the stack.”, from what I understand that implies you need to purchase a slide show stack so my real question here is what slide show stack to use and once I have it how would I go about using the stack to add it to the header image on my “home” page.
Thanks for the help.
