Can you try the latest beta of 7.5: https://dl.devmate.com/com.realmacsoftware.rapidweaver/18719b/1497358375/RapidWeaver-18719b.zip
Can you also try turning off “Verify uploaded files” in the Preferences for 7.5
Let me know how you get on.
Thanks @dan but still no good. Publishing starts and gets to about 400 of 3000 files then fails with an unable to contact FTP server error and unknown PASV reply.
Hi @ChrisL,
Couple of things:
I’m sure we’ll get to the bottom of this, hang on there!
Thanks,
Dan
Hi @dan
Thanks for your help so for
Hi Chris,
Thanks for the feedback.
Can you email me (dan@realmacsoftwar.com) what settings you are using (maybe take a screenshot)? Could you also email me your project?
I’m wondering if it’s got something to do with the plugin you’re using because you’ve said before that smaller sites work
Would it be possible for you to create another FTP account so we can test RW uploading to your server? This is the best way for us to fix your issue.
Cheers
Dan
I’ve got the same issue and reverted to 7.4 until I hear it’s fixed
