A prospective and 3D effect with some stack?
Hi guys,
Do you know if exist a stack that allows you to create 3D effects with images on multiple depth layers such as you can see on this site?
Massimo
Take a look at
http://www.weaverskingdom.com/stacks/parallax-scene/index.html
I bought it but is not the same effect. With Parallax Scene stack there is not the 3D effect.
I did this quickly with big white ducks Section box stack and the tilt option selected:
http://rcobodesign.com/demo/tilt
You can control tilt, glare to your liking. Effect seems to work only in desktop view.
Hi, tomorrow I will take a look.
Thanks very much!
That’s exactly what I was looking for.
Thanks!
Glad it helped!
I updated the link to include the hover on zoom effect. Works smooth on safari, but there’s a little lag when viewing in chrome. Once again this hover effect seems to only work when viewing on desktop.
