How do I add a hyperlink to my other web sites on my main website using RW8?
Thank you for your input.
Select/highlight the text that you want to make into a link. At the bottom middle of RW8 window there are 2 orange buttons. One of them is to make the link, the other is to undo a link.
Yes, I see them, learning curve is still going on.
Thank you.
Just tried it but the orange buttons are greyed out and do not seem to do anything. Am I doing something wrong?
jon try highlighting the text or object you want to link then the linking buttons will light up. M
I see.
I will experiment a bit and think I have got it.
Not straight forward like highlighting a hyper-link and pasting it into a page, as I do with Expressions for Windows.
Just a different way of doing it I expect.
Thanks for your help.
You can also do some code like this and use words (in this case I used Privacy): <a href='https://www.lisasandlerphotography.com/privacy_policy/'>Privacy</a>
It’s in the footer text on all my pages: https://www.lisasandlerphotography.com
What a good way of doing it.
Not as simple as copy and paste then.
Lots to learn for me!
Thank you.
There is usually more than one way to do things
Some better than others, but that works for me. Just make sure you always “paste as plain” without formatting.
There is quite a bit of good video on RW. I recommend watching then testing. Most people try to build their dream site first.
I recommend only buying add ons and software from people that make video that shows how it works and what you can do.
Marty
