Alert Box with anti-annoyance
I’m looking for an alert pop up which is a) customisable and b) has some kind of anti-annoyance be it cookie based or timer based. Principal purpose is to alert users to Terms & Conditions so mainly needs to pop up on page load or scroll point.
So far I like the look of 1LDs ‘Notice’ stack which looks to be a self contained solution, and Joe Workman’s ‘Call to Action’ that looks to add functionality to other modal type stacks (several of which I have). Content could be lengthy and/or mixed so for this application the Doobox Notify stack isn’t what I’m after even tho it’s a useful little stack.
So - any recommendations? Anything else I should be looking at?
Thanks in advance.
Maybe https://stacks4stacks.com/gateway/ - can display text, images, HTML and is cookie-based.
Rob
FloatingContent: https://stacks4stacks.com/floatingcontent/
Call to Action gives you ultimate control over how often to trigger/show an alert to users. Instead of having an opinionated UI, it integrates with over 10 different stacks to allow you to use it how you want to. https://preview.joeworkman.net/call-to-action/
Ha. Now that I read your second paragraph… What if you used my free static height stack to create a scrolling container inside of a lightbox. Then Call to Action to only display it once.
