Hi
I am running rapidweaver 7, I built a simple work website in Allegro, liked it and then bought Allegro Pro, extra features and social buttons included.
My problem is I canāt see where the buttons are or how to look for themā¦
Help gratefully received.
this the tutorial for social icons from a different theme but should be the same process, might help:
http://bltthemes.com/preview/rapidweaver/vertigo/tuts/social_icons/index.html
Did you check out the sample project that came with the theme:
http://bltthemes.com/preview/rapidweaver/allegro/offsite/sample_snippet_project/
hi teefers
thank you for your reply, I did look at this, but could not see how to apply it to theme, I thought that it would be automatically added.
thank you rolisize
have applied code as highlighted in link.
many thanks, it appears to have solved my dilemma
Hi All, I have manage to use icons for website using the code provided, however, I havenāt the code in my sample project folder.
I have deleted addon, deleted folders and re downloaded, but still have the problem.
I tried to get support from Brandon Lee, but that was no help and my questions go unanswered.
The only items I have in the sample folder are images, and a grayed out icon.
Hard to tell from the picture, but looks like thereās a file called āsample snippets.ā Right-click that and open with a text editor and I would guess it contains code.
Thereās a snippet folder (Iām not at my Mac right now) that you should be able to copy and paste those into and access them from the snippet function built into RapidWeaver.
