Hey folks.
I know I’m missing something simple here but the Artful Theme has two columns, one for the photo, the other for the text.
How to I tell it to put the photo or text into the appropriate left / right column? In using the styled text formatting setting it to left or right only moves it within the column, not to the other column by it side…
If I understand what you’re saying, the theme probably is using the sidebar area for column effects.
I’m not at a Mac right now so I can’t check the theme for you, but the easiest way to see would be to place something into the sidebar. It can be opened in one of the inspector windows on the right side of the screen.
Thanks Doug, in the examples for RW8 on Youtube they show a brief scene where the images alternate on the left and right with content opposite. This two column layout is great, just can’t figure out how to trigger it in the layout…
Hmmm I can adjust the the sidebar and main content window sizes … that might be one solution Doug. I could set the sidebar to 1 column and the main content window to 12 and use stacks to implement the two column view.
