Before I drop RW project files into Dropbox I use the Finder “Compress” Archive Utility (File menu “Compress”) to zip them. I have a folder of 11 RW projects and I simply compress the folder.
Lately, due to corrupted style files, I had to go to a backup. When I dbl clicked the zip file and Archive Utility ran it FAILED. I tried a couple other zipped files, they too failed.
the obvious challenges of moving from Intel-based Macs to Apple-Silicon based Macs would be an obvious thing to consider – but i would guess that you would have mentioned that.
so, at that point you really have to start to look at Dropbox as the culprit.
i’m afraid that i’ve given up on Dropbox myself. after about a decade of working flawlessly on much slower hardware Dropbox now consumes upwards of 20% of my CPU when enabled, even on the best hardware. and so many failures that i can’t begin to count – almost always on larger files.
Interesting. I brought this up just in case someone is depending on zipped files only for their backup or to transport, or - to sync two machines. I have successfully unzipped compressed RW files before on my MBP (from dropbox) so something has changed. Perhaps it’s size or number of files. Perhaps the moon in the wrong phase. Who knows.
