Hi, I am trying to put small audio clips in a standard Rapidweaver blog but I can’t find to way to do it, is there any way I can access the HTML code and add it that way? Or is there maybe a stack that I can use to blog, so I can add an audio stack?
You should be able to place the standard HTML audio code in the built-in blog page. As for stacks, there’s a bunch of players, but they would only work with a stacks page (not the standard blog).
Here is some info on the HTML audio player code:
https://www.w3schools.com/html/html5_audio.asp
Where can I edit the HTML code of the blog posts? I want to insert audio clips in different parts of the posts, how can I do that? (sorry I am a total noob).
Try just pasting the code snippet right in with the text just as if you were pasting plain text in.
