Hello my friends,
I did not find any stack or solution to put an mp3 interview in RapidWeaver… But I’m sure there is a simple solution
Thank you !
Here is where you can search for stacks. There are many audio player stacks for RW, and there are additional audio stacks not listed on the community site:
https://rapidweavercommunity.com/search?q=audio%20player
If you’re not using Stacks, this post should help:
Here is a sample Playlister
http://www.ibize.com/RossGoldberg
Thank you David, In between, I found a lot of Audio Stacks on https://rapidweavercommunity.com…
Thanks again
Thank you Joe, I’ll use this one for an other project as it is very clean and very music oriented. Best regards.
Glad I could help.
